ingrahams
Well finally joined the 6.4 crowd (again) and purchased a 08 ccsb FX4 with 82000 miles, after bringing it home it immediately had a 5" DP back flo-pro exhaust installed along with a afe CAI and SCT livewire with innovatives tunes loaded. There has been a little bit of a learning curve on trying to figure out how to set it up just right. I have found that the XStreet works the best for me, however when i put in XRace it shifts like crap (trans learning?) and then it will go into reduced power mode. I forgot to pull the codes before I cleared them and went back to the XStreet so I just curious if anyone else had issues like this. Also when i am running the xstreet the CEL will come on with the following codes...p0480, p041d, p1000. I m not sure what the fan circuit has to do with anything I have done but would the egr temp sensor code go away if I selected that I had removed the EGR system in the sct? Would that deactivate the system even though it is still on the truck? Thanks for any help
-Stew
-Stew
