GatorBaitR6
Ok so many things out there for and against... What are yalls opinions for installinga RR for our fuel systems... For the record I intend on 190cc injectors, turbo to support, air dog 2 or equivalent, and water meth...
The RR removes the fuel bowl right...? With the Aeromotive fuel pump... is it anything like the dead dog 2 lol... Is it pressure adjustable or is everything adjusted from the RR... just dont wanna have 2 back pressure regulators fighting one another...
Depends if you want to or not, not all of them do simply because you need to have proper filtration in the system somewhere, and just deleting the bowl without having the right filters... well you know where this goes.
I dont recommend the airdog and a regulated return, unless theyre properly setup they fight each other. Just too much bad luck for me to ever recommend and airdog 2 unit to someone. There are better systems out there.
So I've read... Does the areo have a reg on it...?
no but its always running at 100% duty cycle unless you get the pump controller which is an added expense. This is why I recommend fuelab, they can be set to reduced speed which is meant for continuous use.
