When I purchased my truck it already had a 6"lift installed. I've gradually replaced the weak links
-replaced trackbar drop bracket
-5160 shocks
-poly bushings on most parts.
the lift uses a block in the rear and 6"lift pack in the front.
the lift springs use a red poly bushings with a out "lip"that gets pinched between the mount and spring eyelet.
Well they are toast. the eyelets on the rear have shredded the bushing and needs to be replaced.
since in have no idea on the brand I can't figure out the bushings I need. I think I've narrowed it to skyjacker of procomp given the old part number I could dind,fd500 on pitman arm
I have a master kit from energy suspension and it came with bushings for the factory springs. Now my thoughts are the lift manufacturer would use a factory size to aid in replacement. On the other hand a manufacturer could have the spiNg designed to use their bushings only.
so can anyone give me idea on were to start.the bushings are red,differential spacers ( multiple not one piece)
So if anyone can point me in the right direction it would be helpful
-5160 shocks
