REV-X
dzldoctor
Anyone use the rex-x in the 7.3 with as good of results as the 6.0? Have a 7.3 with about 165,000 starts, has no power when cold. Like sticktion in the injectors. Curious if rex-x haas seen the real world results on a 7.3 as it has on 6.0.
kyle43335
works just as well on the 7.3.
Paul@CP_Trucks
Jasper, Texas
We sell a TON of it for the 7.3L and 6.0L it works equally as well. If your interested we can get you out a couple of bottles to try.
Chris,
Here is the best way to put it....
Never before has the proper oil additive package been so instrumental in protecting todays high performance diesel engines. With the EPA mandating the removal of key lubricating components such as Zinc, Sulfur and many more from today's diesel fuel and engine oils the consumer has been left with only one choice for complete protection. REV-X performance oil additive fills that gap and then blows the previous specifications away with above and beyond performance and protection for any lubricated component in your pride and joy!
Benefits of using REV-X Performance Oil Additive in Diesel Pickups:
Increased Efficiency.
Increased Horsepower and Torque.
Greatly Improved Cold Start Operation.
Smoother Operation of all Treated Components.
Dramatic Reductions in Component Wear.
Reduced Thermal Temperatures.
Reduced Turbo Spool Times.
Enhances FORD PowerStroke Injection Systems for Proper Operation.
Whether you are looking for additional protection, efficiency or an increase in performance to make your truck run better than it did when it was new. REV-X Performance Oil Additive IS the only real world solution.
dave186
Idaho
I have been running it for about 500 miles now in my 7.3. My injectors only have about 20k on them so I didnt have any real issues with them but I do notice that it starts better when cold and is a bit quieter. I havent decided if I will spring for another bottle on the next oil change.
