Echo
I changed the fuel filters on my truck yesterday and also removed the cover on the water separator to clean out the drain area. I cycled the key 8 times to let it purge the air. It seemed to run fine yesterday with no smoke but today I started it and it is idling rough and I'm getting smoke out the exhaust. Also when I put it in drive the injectors are making more noise then normal. I did load a towing tune on it today before startup so I'm hoping reloading the tune will do the trick. Do you think there could be air in the system still?
Edit
I'm running the crappy canned sct tunes and my dpf is deleted
Edit
