Scangauge 2
NHL_bullitt
Illinois
I've searched on here, but didn't find much info, and most threads were in reference to the earlier model. Anybody here run the Scangauge 2? Needing to know ficm voltage, oil temp, coolant temp, etc... I just picked up a 1 owner 2004 and it runs perfect right now but I have no monitoring system at the moment and not sure if the Scangauge will tell me what I need to know. I appreciate it.
bretferd
Cape Coral, fl
Yes the scangauge 2 will read those 3 things It's part of their x gauge system. You have to program those pids in.
There is a good video on YouTube, search 6.0 powerstroke scangauge. Dieseltechron is the guys name. (My phone isn't letting me post the video).
NHL_bullitt
Illinois
Thanks for the response. I'll check that out. Nice wheel choice btw. I bought those for my 01. Then bought them again for this new truck but went with the gloss black ones. Salty roads eventually get the best of chrome wheels here in the winter. :fustrate:
atc500
Utah
I just set my Scangauge II up it does all those Ficm low Volt Ficm Main Volt Oil temp water temp even trans temp and a lot more those are just the ones i wanted
NHL_bullitt
Illinois
Thanks! It seems like bulletproofdiesel sells them already set up for just a few more bucks too.Curious, what did you guys end up doing to mount it?
bretferd
Cape Coral, fl
I have a 4x4 shifter on the floor so this is how mines done. Hard to see the top right number when in gear but I still like it.
swinky
Eastern, Nc
Mines just on the column. It covers up the thing that shows you what gear your in. Very easy to read though.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
turbie
West Jordan, ut
I mounted mine on the dash in lower left corner of the windsheild, with the velcro they
supplied in the kit. i can see all 4 monitered sensors, plus i can see my a-piller gauges.
love the scan gauge!
