Marty
Scanner won't connect, truck is not starting.
2000 F450, harness was eaten up at several plugs and not making connection. 42 pin connector was stripped so I replaced engine harness from a 2000, replaced chassis harness from Late 99. Both were in working order prior to install.
It's not a bad pcm or IDM. Both were swapped with same issue.
It's not a bad ground, the truck started and ran prior to this just missed on cyl7. Everything is right (keys, modules, etc.) on scantool. Scan tool will work on truck right next to it.
No blown fuses. PCM is installed correctly.
No wts light, fuel pump does not kick on with key forward. It seems like a PCM issue but it's not. Truck is bone stock, no chip.
Thoughts?
Thoughts?
