School me on up pipes
eng53ine
Ohio
What's the difference/gains of the bellowed up pipe verses stock?
What are the chances off the stock pipes be beyond being resealed my passenger side has soot at the top read a few threads but not sure of the difference between the two. Thanks
02 ccsb, lariat, 7.3 auto, 4x4, 4" duals, 6637,zoodad
superduty4x4
Newport, WA
Bellowed up pipes have a flexible section of pipe so that the pipes can move/expand with heat. They allow for a better seal because both ends of the pipe are bolted down solid. The stock setup uses a gasket at the collector end that wears out in time, and can wear out the up pipe to the point that a new gasket will not seal and you'll still have a leak.
ToMang07
Mainah!
ok thanks best to go with international or aftermarket?
International. Some have had very bad luck with aftermarket. Typically aftermarket have quality-control issues....so if you want to roll the dice, go for it.
