SCT TSX EOT???
Nic
Santa Fe, Texas
i have the latest firmware 1.1.111 - cannot figure out why i dont have EOT in the options...tried all the pid options..spoke with sct today and they say i should have the option...any one else having this issue?
GatorBaitR6
Gray, TN
There is different ones for 6.4, common diesel parameters and something else... I don't have mine right now and eot is not on one of the options
Nic
Santa Fe, Texas
Early 6.0s do not have some of the PIDS the later ones do.
youre exactly right...just got off the phone with SCT...dang..im assuming theres no way to get EOT off of the early 6.0s with out running a custom gauge unit :cursing:
Nic
Santa Fe, Texas
my buddy has an 04 too and he has it..mine is considered an 04..but its a july of 03 according to the door. his is december 03 but considered an 04 but his and mine are different - he has 03 plumbing but 05 hpop and rails, different turbo etc...has mix matched parts
GatorBaitR6
Gray, TN
yea ive met another guy who had an 04 with 05 stuff all over it... wonder if it was the factory or a retarded previous owner...
Nic
Santa Fe, Texas
lol right in the later part of certain years you see that on some trucks...door date gives an exact. Just like FICMs also...for FICM matching you really need the date off of the FICM instead of the vin for the date..i guess its more precise.
JD3020
Farmersville/Dayton, Oh
I'm having the same issue with my brothers TSX, and his truck is an 06. I upgraded the monitor and dongle to the latest firmware on their website, but it still won't show EOT on the common diesel PID's. Before the update i could get into the 6.4 readings which had EOT, but it was a weird number. Now after the update i can't access the 6.4 readings because it says "cannot find DLX" or something like that. We called and left a message with SCT but i don't think they have called us back yet.
Nic
Santa Fe, Texas
mine says that sometimes too "failed to scan dlx" i think it doesnt get quite a clear stream of blue tooth connection at times..hence the wild range of numbers it goes through on certain readings like boost..i just click it again and it will go through eventually. talked to the guy this moring and he says it isnt the tuners fault. its the trucks because the earlier ones dont have the EOT as an option in the PIDs. newer ones do. Try and re-populate the list and see what happens. It should show it on an 06...according to SCT lol
JD3020
The bluetooth thing makes sense cause it also did it once when i was trying to just get into the common diesel PID's.
I really need to talk to SCT though cause i did everything i could think of to make sure it was update and reset, but it still never showed EOT on the list. But i don't know what re-populating the list is, so i might not've done that. :shrug:
GatorBaitR6
Gray, TN
When mine does the dlx thing I restart it or try and connect again... And thr wierd number u see Is the oil Temp... Don't ask me y but sct programmed it to be in *C... It took me two weeks to find this out... Just do the conversion C* temp X 1.8 +32 = temp in F*
