sct tuner problem
white07psd
I have an xcal2 in my 6.0. the problem i am now having is that when i load some tunes, it'll start right up then cut right off. i've erased the programs, reinstalled them into the tuner with no luck, i got vivian to send me a new looney wild and no luck. It also does it with my rcd tow tune... i talked to vivian about it and she really didnt know. No recent updates or new programs, same tunes i've always ran. The only difference is a new 58v ficm from vivian and idp ficm flasher which is an awesome combo with my race tunes. i can still load my insanity, looney wild track, super panty dropper and xtremex but its just the 2 tunes that i know of that does it... Is my xcal2 getting wore out or would it be something with the truck???
Franchi
Columbus OH
If other tunes are loading fine, then it shouldn't be the x2. The x2 will either work or it won't, they don't really get wore out. I assume though you are loading all the tunes using the SCT livelink program as the x2 can only hold three custom tunes and you listed 6 but its only happening with two of them correct?
white07psd
I use "live link ford". Yea the x2 only uses 3 tunes. I just dont understand why it wont run with certain tunes anymore. Nothing has changed with the x2 or tunes.
white07psd
The innovative ficm tuner cant be removed. Once its installed, it cant be pulled out
sent from the stool.
