Strokersace
Selling a set of 2001 axles that are setup for an OBS. They have all brackets, shock mounts, driveshaft yoke, sway bars, brakeline adapters, etc changed over to the OBS. Plug and play to run factory SD disk front and rear.
Out of a 2001 f250. 3.73 gears. 125k miles. Ran under the OBS for the last 25k. Work perfectly but want to go to an 05+ coil setup.
Axles still under truck and will remain under until sold.
Located in Wichita Kansas. Again, nothing wrong but am removing lift kit and want a stock hight and better ride for my old man.
You will need to run 8x170mm SD wheels with these axles.
$1000 plus the ride.
