SD or OBS pitman arm?
ytee
Does anyone know if a pitman arm from a 04 Super Duty will work on a OBS?
Chris
ytee
Thanks I need one for my OBS and I found a SD one laying around the garage is why I was wondering.
Chris
Diesel_Brad
Gilbert PA
SD has a Larger Diameter sector shaft than the OBS
SD had a different offset than a OBS
SD is longer than a OBS
IIRC the tie rod is bigger on a SD
So, No, it is different
