SD swap question.
blackcloudpsd03
I'm helping a friend do a SD swap on his obs its a later model 97.. We had everything layed out. And we argued over the exhaust manifolds... Witch one is witch ? Is the SD manifold the one with the gap between the last manifold bolt and coupler or do I have it backwards? To me it looks like he had the SD manifold
It had about 1 in before the coupler. (The coupler isn't right up on the collecter ) I will post up a pic in the day light
Next question. If he does have the SD manifold and up pipes could you just that the t4 off and slide the vband on it and call it done?
blackcloudpsd03
That's what he has on his truck.. SD or obs manifold.
blackcloudpsd03
Are the actual up pipes bent the same way? Obviously the pipe lengths are different? I take it?
