SD vs OBS Exhaust manifolds...
CSIPSD
Bend, OR
What exactly is the differance? Its only the passanger side right? I have a set of OBS manifolds, but not sure if they will work for a superduty turbo kit???
rpm-inc
Saw your wanted thread. I have a set of e99 manifolds you can have if that helps.
CSIPSD
Bend, OR
If E99 are the same as L99 I would love to take them off your hands.
Anyone have anymore input? If one side is different and not the other (as I recall) then I only need one.
chris1978
Kamloops BC Canada
I'm running e99 manifolds. All the L99 stuff bolted right up no issues.
And I think its the drivers side that needs to be changed on the OBS.
Tom S
A little cut and paste from my conversion article. The coated ones were for the swap to a 38r and the other ones are from my OBS. The driver side manifold has a longer outlet piece.
SuperDuty Drivers side exhaust manifold F81Z-9431-AA which is a Ford Only Item
There is a difference in length at the outlet VS the OBS manifold. I am aware of others that did not swap out this manifold using standard up pipes but I was I wanted to be sure on the alignment with the bellowed up pipes.
I also purchased a new SD passenger side manifold at International to send to be coated. I think the OBS manifold would have worked fine. International 1831025C1 or Ford F81Z-9430-AA
CSIPSD
Bend, OR
Perfect Tom...
Picture is worth a thousand words.
You can see the casting for the last bolt and the up pipe clamp is one and the superduty there apart.
