Second rear main seal
WYO7.3
Wyoming
Hey guys like the title says my truck is leaking oil out of the bell housing bolts again. The first time it started leaking out of the bell housing bolts I took it in (99973 miles) and was diagnosed as an upper oil pan gasket AND the rear main seal which I thought was odd they both had issues at the same time. After 1000 miles its leaking again from the same spot. I called the dealership they told me it's probably just the left over oil that got slung around from the oil leak. It pissed me off they wouldn't clean it out but that's for another day. It's been another 700 miles and it still drips. Could it be possible it lost another rear main seal? Is there any common issues from leaking out the back of the motor? Now that the truck is out of warranty I'm hoping it's an easy fix.
WYO7.3
Wyoming
Sorry I didn't mention it but it's on my 2011 6.7. It's definitely not from up top you can start it up and after a few minutes see it start seeping oil from the lower two bell housing bolts.
