Serpentine belt failure..
hwrdbd
Couple years ago I had to replace my serpentine belt. I didn't get one of the ribs all the way onto a pullet and once started it took that one rib of the belt clean off. Ran the belt no problem until this week. After doing some work I put the belt back on, and with my previous mishap in mind I took extra care to make sure the ribs of the belt were all aligned on the pulleys. 99% sure I had it on proper lol.
Well I went to check my oil this morning and it seems that the belt decided to unravel itself a bit more. Another rib separated from the belt and wound itself around the ac compressor pulley, the idler pulley, and scattered a few pieces around under the hood. The belt also seemed to come into a disagreement with my oil dipstick.. which is no longer a part of my truck.
So moral of the story, keep an eye on the condition of your belts...
ToMang07
Mainah!
No.
The moral of the story is do it right the first time, and don't half-ass it like a dumbass. :slap:
Did you at least get the gates upper radiator hose for dual alternator setup? (Or have it already?)
hwrdbd
What is proper method of checking tensioner? It certainly doesn't feel weak, even compared the one I just replaced on a friend's truck.
And what does the upper radiator hose have to do with anything?
mandkole
Northwest
At Gates, our marketing guys came up with 'spin-cycle'...
1) you spin the idler pulley feeling for any stickiness. As bearings throw their grease out over time, this is usually the first thing that fails on our tensioners.
2) Then, you cycle the tensioner arm feeling for notchiness, or difficulty in rotation. Many of our competitors tensioners will quickly lose their damping and often the pivot shaft support is weak and if this breaks, it will begin to misalign the arm. This then misaligns the pulley and belt which will quickly lead to belt chirping then in extreme circumstances, fail the belt.
In your case, it sounds like you damaged the tensile cord in the belt which began to kill itself over time.
The radiator hose runs on the other side of the belt. Gates.com should have some tech pages on it or youtube videos.
http://www.youtube.com/user/GatesAutoAftermarket?feature=watch
greyford1979
Copley,Ohio
When my tensioner went bad it didn't really feel weak either, but the pulley was making noise. But compared to the new one I replaced it with, it was definitely weaker. My tensioner also was separating at the bottom of the casing when I replaced it.
littleredstroker
where the antelope play
Least this didn't happen lololol
sent while staring at a windowed block
POWER-STRUCK
Indiana
if you see a gap larger than 1/8" between the 2 aluminum bodies that house the spring. then the tensioner is bad. dayco and gates make a replacement that is better than factory
vatozone sells them with a lifetime warranty.. in my case i bought one a couple years ago and both my 7.3s and my brothers 02 7.3 have new tensioner's on them with only one original purchase....
Arisley
Arlington, Texas
Betcha when you put the belt back on, you put it on turning the opposite direction. It was already failed from the first time you put it on, then turning the other way just finished it off.
The dual alternator radiator hose allows you to remove the belt without removing the hose.
hwrdbd
Well apparently I've had the better hose on my truck since I bought it a couple years ago, never had to pull it to change belt. I'll look into my tensioner. Thanks for the info.
Arisley
Arlington, Texas
Yep, most auto shops sell it as the preferred hose, if it has been replaced, most tomes it will be with the good one.
