duddy
08 F250 CCSB with H&S mini maxx, dpf delete and intake.
Last night, on my way home, the little wrench light on the center display came on. figured id check it out this morning. When i pulled in to the apt the idle rpms in gear climbed to 1500 until i hit the brake, then dropped down to normal, after i took my foot off the brake the rpms climbed again, and repeated till i parked.
This morning i went in the mini maxx and found no codes logged and the light and symptoms are gone. I dont have acces to a scanner till tomorrow.
It only does it in gear, in park idles normal back in gear when you let off the brake it climbs.
I did do a nice boosted launch leaving my buddies so i am wondering if there is a throttle fault that causes this. No check light, just the wrench light.
