shackle lift
brian89
Penisylvania
If i put a 4 inch shackle lift in the front, what size blocks would i need in the rear? Just trying to find a cheap way to get up off the ground a little bit till i can save up and buy a full lift
Cory S
orlando fl
to get 4 inches you will need shackles and hangers, along with an adjustable track bar. 4 inch blocks will put you in the level ballpark.
NotStock
Tucson, AZ
You will want a 1/2" taller block than the front lift amount for the truck to sit level. As Cory had said, you will want to do a drop track bar bracket and pitman arm aswell. We have ask of the components you will need, if you want pricing just shoot me a pm.
TARM
He will not need the adj track bar with the bracket correct?
Cory S
orlando fl
yea the either (drop pitman arm, & track bar drop) or (adj. Track bar) i have great luck with the adjustable track bar with my 4 inch lift.
Betarocker
Sea to Sky, BC
If you want to go the most cost concious route, then figure out your ultimate goal with respect to height. The cheapest way to lift a truck is to do it once. You won't save money by doing it in stages, unless you know the parts can be reused as you go higher.
