TheSmokinStroke2002
How do i get the slave cylinder wedged between the bracket and clutch fork? Zf5 trans.
Sent from my DROID RAZR using Tapatalk 2
Push really hard. Also remove the master cylinder cap and get some fluid out so when you depress the rod it does not overflow. That is about all I can remember from doing it last summer, but luckily for me I had to remove it last night to get the oil cooler out, so i'll be putting it back on today. Wear some gloves and possibly put a rag on it for more padding because if I recall correctly my hand hurt like hell after it finally went on. That and it took a few tries to get it. Good luck.
How about a big C-clamp on the cylinder to compress it, slide it off and throw it in.
