So I guess seeing about codes is next
average
Central PA
7.3 will start fine when cold, it sits for a few days at a time now that I'm driving the mustang. After it warms up the thing will just keep cranking and cranking. Sometimes if I keep cranking it will finally start, most of the time not.
Fresh 15/40 Rotella oil, oil and fuel filter and international CPS. Tried starting with ICP sensor plugged/unplugged. No SES lights. Fuel bowl is full of diesel. HPOP resi is full of oil looking via the hex access at the top.
Had a SRP 1.1 installed a little bit ago, injectors have about a year and a half on them. EBPV is deleted, 38R turbo.. no visible leaks anywhere, makes good boost when running, smokes in the hot setting as it always did.
When the motor starts cold, warms up it runs great just like normal... it's restarting it after shutting it off warm is the problem. I don't have a code reader/scanner otherwise I already would have ran the codes.
JLDickmon
sounds like a plan
get a Windows XP laptop off craigslist, and get an AutoEnginuity software bundle.. bet you're out for under $500.
