Lick Dicker
Hey guys, My key stoped starting my truck a few weeks back, when I turn the key I can hear a relay in the fuse box click, but the solenoid will not activate, unless I put a jumper cable to the signal termnal on it. I did a quick check of fuses but didnt find any to be dead. My crusie control also does not work and am begining to suspect it may be the switch that tells the truck when the clutch is in. Is this a common problem? Is there anywhere you can point me to diagnose this further?
Thank yah much!
Thank yah much!
