They retail $60 new, I'll take $30 shipped!
The Overboost Eliminator keeps the Ford PCM from defueling due to exceeding 24 lbs of boost, which can happen regularly if you have a chip, programmer or other modification. This is a complete and total plug-in solution. No adjusting blow off valves, or complicated plumbing. Plug this in and dial the boost up. Don't forget to disconnect the red pressure line to the wastegate actuator. Other mechanical solutions dream of offering the accuracy, reliability and simplicity of our unit.
Others may claim that our product reduces low end power...FALSE. Our Overboost Eliminator only comes on when it's needed and it shuts off when it's not needed. Why spend more to get more hassle? Call it a 'doo-dad' or whatever you want, but it's the #1 best selling solution to 7.3L Overboost Code Elimination on the market. Save the plumbing for your toilet repairs. This is an electronic solution to an electronic issue in modified PowerStrokes.
The Overboost Eliminator installs easily in about 30 seconds and uninstalls just as easily. It leaves no trace, no greasy hands and no guessing or setup.
