lariat 7.3
- Joined
- Dec 2, 2012
- Messages
- 658
- Reaction score
- 0
Long story short, blew the back of the stock HPOP off. Put in a T-500 with the IPR from the stock pump. Ever sense then i've had a stumble when rolling into the throttle when its in overdrive. Had the tunes re written because it was going over 3000 psi. Ran fine other than the stumble is still there. Truck now cranks up sounding like a huge cammed out dragster, pedal is touchy when its doing this issue.
Rev it a hair and it generally goes back to idling smooth. Sometimes just shuts off like a CPS issue. Had it happen this morning with the computer hooked up and it threw these codes.... Also monitored cranking ICP and IPR values and recorded them, It was running rough when i did it. SOOO IPR bad?
[/URL][/IMG]
![20131128_104551_zps025db084.jpg](/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fs1230.photobucket.com%2Fuser%2Ftagracing%2Fmedia%2F20131128_104551_zps025db084.jpg.html%5D%5BIMG%5Dhttp%3A%2F%2Fi1230.photobucket.com%2Falbums%2Fee497%2Ftagracing%2F20131128_104551_zps025db084.jpg&hash=90908ff7d40664881a12d9c03d28a86a)
