Starting my build, have few questions
Blacksmokin22
I have a 2006 single wheel 350 ccsb, with 6" lift 37's on 22's. Ill be doing warren 190/75's, reg return, fuel lab fuel pump and custom filtration, tank sump, mtw stage 2, absolute performance egr delete, & head studs. I'm curious as to how much hp I will be in the range with this setup? And not quite sure who's programming to use and/ or to use php ficm tuner along with custom tunes. Worth the extra money or not? Or have the ficm voltage upgraded to 58v be worth it also? Anybody have any suggestions my ears are open. Thanks lets hear some feedback
Jeremyleggett07
Katy, Tx.
Have u done research about Warren!? Just sayin cause what I've seen and read about. Not tryin to start anything, just askin. I've read about great HP gains from just adding a FiCm tune with everything else stock, so I believe it will help. The 58v FICM upgrade won't help HP wise but may help with voltage loss to injectors overtime and with any cold starts as well.
05wh250
hendersonville, nc
Warrens has great customer service. I use innovatives but tunes are really more personal preference. Might try it before ficm tuning alot of guys don't like it with bigger injectors.
hawgdoctor
king george, va.
With that setup you'll be around 550 at the wheels. Tuning is purely up to you. Have used just about everybody there is, but MY preference is gearhead. The ficm tune with those injectors I would loom at innovatives mild flash. Not knocking bill at all, but his are geared towards stock injectored trucks. I do believe he is working on tunes for the bigger injectors, but he would be the one to ask.
sent from the shop making things fly.....
