ODAWG714
Well I got around to installing my steed speed manifolds last week and got to driving around so I'll make a review and post more as I drive.
The install is pretty easy.
The turbo will need to be removed for pipe replacement.
Both fender liners will need to be removed as well as the downpipe.
The oem bolts were re used and torqued to 32ft pounds
At start up you can hear a slight change in exhaust tone.
While driving and accelerating the truck feels like it has more top end and climbs to 100mph a lot faster. Low end feels the same an mid is alittle stronger. Max egt is 1180-1190 wot with 3 different race tunes from gear head/tsd and dfuser.
Previous egt were 1290-1300 at wot
When hitting Max egt and releasing the throttle the egts get cool very fast. Will post pics and videos later on.
Over all I am impressed I know with some injectors I'll for sure feel the positives out of this setup.
For up pipes I'm using elites uppipes and it's a cab on install . I will be trying some cutting edge up pipes to see if there is a difference in spool since the pipe diameter is smaller. I'll keep ya guys posted. Thx leen at steed and jd at elite for the great support.
