Steering Wheel Clunk
dohcter
Has Anyone run into a steering wheel clunk mostly when your in a reverse and turning, then straighten the wheel. Its in the column, not in the steering. The noise is up high in the column. Sounds like an upper intermediate shaft. Any one else have an idea? Thanks :D
Edit: i should add its a 2010 f250
WoodBoy
Alabama
Mine has done it since new. Every morning it does it because i back up and cut hard to the left at the same time. After it does it once that morning. No more noise again
dbs0026
Check the track bar bushing, mine does it going forward and in reverse. The bushing is shot and I need a new one.
BFT
southern cali
Same here with the bushing on the trac bar. I have steering slop as well but no clunking when I turn.
GROSSpolluter
So Cal
Mine has done it since new. Dealer couldn't figure it out. I layed under there while someone else turned the wheel. It's the bar that links the 2 wheels together had them replace it new one does same sh!t. Went out on the lot to another truck it does the same thing...maybe upgrade to heim joints?
