Sterling 10.25 gears into a sterling 10.5???
rat49f6
Vernon,NJ
Can obs gears be put into a sd axle... 10.25 into 10.5
My obs has a 10.25 with 4.10s and I got a sd axle but it has 3.73s I was wondering if they are interchangable
Sent from my SGH-M919 using Xparent Green Tapatalk 2
strokindt444
yes if you buy aftermarket gears for a 10.5 they actually sell you 10.25 gears so yes they will work
dzldoctor
I did that a while back. There is a difference in the pinion bearing from the 10.25 to the 10.5.
rat49f6
Vernon,NJ
So use 10.25 gears and 10.5 pinion bearing?
dzldoctor
I don't quite remember, but I think you need the front pinion from the 10.25
