CamTom12
Ok, I wasn't sure if this should go into tech or aftermarket, but here it goes.
When I cranked this morning my truck sounded like my old 7.3 and ran rough for 2-3 seconds, then smoothed out to the normal, quiet 6.4 idle. It was -30*F but I was plugged in for ~3-4 hours prior. EOT/ECT both read around 40-50*F when I turned her over. I'm going to get a video of it tomorrow, should be around the same temps.
Having never cranked my truck in weather that cold, I wasn't sure if that was normal or not so I went to talk to my buddy. He hooked a computer up and we checked my short term fuel trims at idle and most cylinders where near 0 except cyl1 reading between +3 to +4, cyl2 reading between +6 to +8 and cylinder 7 reading somewhere around -2 to -4. EOT/ECT was near 150*F #it's hard to hold EOT/ECT in -30, even in high idle#. I put it in D and once the idle settled back down with the load the trims on all the cylinders kind of leveled out to much closer to 0. I'm going to try to swing by there again tomorrow after I get EOT/ECT at 180 and check before the temps fall and see what we read there.
I know all those are within limits, but could this be indicative of anything?
Mods as follows:
EGR Delete w/ WG; KEM 345 on DashDaq; Intake and DPF delete; Engine oil pan heater + block heater
Mods as follows:
