stock turbo and stage 1s
kadeninabnitt
Martinsville, IN
I'm thinking of doing a set of rosewood stage 1s just got enough coin to do injectors atm will the stock charger handle them? later down the road plans are a d66 and an adrenaline pump and possible 30% nozzles swapped on the injectors.
backwoodsboy
Merica
go stage 2 and detune until you have your supporting mods in order. Cheaper and easier to send a chip off than injectors.
bad12jr
A d66 not spooling with stage 1's ? Its not that big. I can bury a 30 lb boost gauge with a set of stock ad's on my obs.
Lang
Doesn't a 38R flow more and spool faster than a D66?
mandkole
Northwest
I was being mildly sarcastic, but the d66 really can handle a lot more fuel than stage 1's.
For a few minutes...
Guys give it more fuel, but just because you can, doesnt mean you should. Ive seen the D66 make 425 or so on 238s, but it was unhappy. The D66 only provides a little more air than the stocker, but its no different than a stocker. Drive pressure kills it just like a stocker.
Stage 1s are all Id run on the D66...
always-strokin
Really? Then why does Beans say that its an easy 500whp turbo w/ efuel, trans, intake/exhaust? I've seen lots of d66 builds making 450-500whp depending on other mods.
I mean, we're talking a stock tp38 w/ 59mm compressor to a d66 w/ a 66mm compressor wheel... thats quite a jump in size.
