89 Stroker
truck is back on the grind of not starting , been an on going problem , truck starts when it wants to , whether its first start of the day , or after it just drove 100 miles , some days it fires right up and other it keeps cranking with no start , some days when it does start , even at operating temps when i shut it off , let it sit for a minute and it wont start back up just keeps cranking and cranking , im lucky ounce in a while it barley catches and fires , only way to get it to start is with a pinch of ether , i know my gp system is not working properly , but at these temps there not needed anyways , was recently at a local diesel shop and the ford dealer , between the two they told me it has good compression , good fuel pressure and passes a buzz test , dealer said the injectors could be binding up? truck does not miss a beat when running , no codes , no cel , everything works as it should , wts light all that stuff works , here is a video of what it does , hopefully i can get some help
https://www.youtube.com/watch?v=J9mDCSvghnA
