Helpin ya out:
Here goes, selling all kinds of stuff. Giving up on projects to move on to better things.
IH dt360 long block head is currently off, has cross hatch, ran great) $1500
500cc p7100 (was a brand new cummins reman before being modded, built by contagious diesel performance) $1200
IH 5x.020 single feed injectors (built by contagious diesel performance) $900
PBM 190# seat pressure springs with retainers and shims $400
Manton pushrods (don't remember the specs, but heavy duty) $350
IH 300/400 series pump adapter (for p7100) $225
IH 300/400 series pump gear (for p7100) $225
NOTHING ABOVE SELLS UNLESS I HAVE A BUYER FOR ALL ITEMS
Cummins 12v block (fresh bored, needs finish hone) $800
Cummins 12v crank $300
Cummins 24v head (bare) $300
12v and 24v front gear housings $40 each
Isb oil pan and rear sump pickup tube $100
24v injectors (stock) $200
01 Allison 1000 transmission in excellent shape (stock) $1200
Tcm for Allison $300
Sae bellhousing (to mate to dt360 or cummins) $200
Allison at545 transmission $400
01 duramax cp3 and rails $350
Ford 460 block, crank and heads $250
Chevy 366 big block $250
Gm AAM 1150 rear axle (40xxx miles, perches moved to fit ford) $600
1995 ford f350 4 door cab with doors (repairable) $500
Ball joint ford Dana 60 4.10s $900
1995 ford crew cab long bed 4x4 frame blasted and primed (modified for different engine) $800
Need all this stuff gone. All prices are obo! Text only, have many pics upon request. 651.two six three.1497
Edited 1 time(s). Last edit was three days ago by swamp_ratt.
Reply Quote
