Suggested tire psi
Cknox121
Augusta GA
What psi are you all running with 35's ?
Trucks a 08 f-250 with 35/12fidy/20 mud grapplers. The tire place put 50 psi in them currently.
Sent from my cracked iPhone using Tapatalk
Lang
For what purpose? Daily driving? Off road? At the track?
Lang
I max my tires out on PSI for daily driving... Get better mileage. Should be on sidewalls
jdc753
Norton, MA
Every vehicle and every tire I have ever had gets run within 5psi of the max. Always had good results.
Betarocker
Sea to Sky, BC
I run 38psi front, 35psi rear. I have 37x13.50LT18 though. When I had 35x12.50LT18 I ran them 40psi F, 37psi R. Towing or heavy loads I add air as needed.
Wear was most even then. Running higher pressure wore the middle faster, lower psi wore the shoulders faster.
BBottoms
Buffalo, KY
I've got 35x12.50R20 Terra Grapplers. When I ran mine at 65 front/60 rear the center of the tread wore faster than the edge. Not a huge amount, but enough that it was noticeable after ~15k. I recently dropped to 60 front, 50 rear. It does ride a little better and I haven't noticed any significant drop in fuel mileage. I'll have to get a few more tank fulls to know for sure if my average is dropping. I may try dropping the front to 55 and see how that does.
There's always the old chalk test to see what your contact patch is. I may do that out of curiosity, but I think 50psi is the lowest I'll go regardless.
