Barnbuilder
Did the Super 60's come with the automatic lock hubs for the shift on the fly or were they manual hubs?
Are the super 60s the ones in 450 and 550 trucks from 05up?
up to 2010 before the 6.7 is a pulsed vac using a different strength and duration
I don't know if the 6.7 has something else ? haven't really looked ( Hotrod you got a picture ? )
the manual or Auto hubs were both available ( manual t case = manual hub ) and look the same for the PVH ( hub ) so if the wording faded you can't tell the difference but the manual is missing some parts
Since 2002 when Ford switched to Dana 60s they have had 35 spline inner axles. In 2005 they switched from 30 spline outers to 35 spline outers. The F-450 and 550 Dana 60s not only have larger knuckles but also different axles with larger u-joints to take advantage of the increased space inside of the knuckle.
I found one on craigslist for $1500. Was wondering about it for my '99. The larger brakes and tighter steering would be nice.
