woodduck97
I got 2 7.3 super dutys I need to fix a leak on. Both look like they are coming from the turbo pedestal orings. The exhaust back pressure valve rods are dry. Is there anything else back there that may be leaking?
It is coming right from the valley and wet all where the turbo mounts to the block but I wanted to make sure before I charge them to do the work. Also turbo forward is dry.
