Surge issuse
Wemoy1
PA
The title pretty much says my question, I am running spartans tunes and I have a bad surge when I have between 3 and 10psi of boost. I can watch my fuel rail pressure jump between 10890 to 14565 when I am cfruising between 55 and 73. When the symptoms start they don't go away they get worse. Has any one had this issuse or know mayb a direction to point me in. Thanks
Wemoy1
PA
yes stage one ported fuel rails and im not sur ewhat the temp was I didnt think to look. I was noticing it real bad on the 150 tune the 210 tune was worse. After it sat for 2 hours in the cold it didnt do it on my way back from the mall which is abot 42 miles from my place.
BBottoms
Buffalo, KY
Several people one here have had issues with ported rails on stock fuel causing surging. Some have been able to take care of it with custom tuning tweaks. Others have had no luck fixing it and resorted to removing the ported rails. Some people have no issue at all with them.
Here's a thread about it started by the guy that built my truck and whom I bought my truck from.
http://powerstrokearmy.com/forums/archive/index.php/t-17624.html
Dzchey21
wyoming
Try unplugging the fuel temp sensor and see what that does, it will make your fan run at low speeds and put a wrench on the dash but otherwise function normal, report back
Wemoy1
PA
ok thanks BBottom i will check out and I will Dzchey21 Ill see what the fuel temp sensor does for the truck I wont get it out til thursday for duck hunting on the lake so I wont have a response til then. Thanks
Just curious though were is it located?
Wemoy1
PA
Ok I found the sensor I was being dumb:morons: but I went for a drive the fuel temp was around 58degrees and the sensor was unplugged, never got a wrench in the dash and the fan never ran except at a stop light. I ran around 70mph and the truck did the same symptom just not as bad. I noticed it surged at idle when it was unplugged this was all on Spartans 210 tune. outside temp was around 38 degres
Dzchey21
wyoming
Not sure I know the factory fuel cooler pump doesn't turn on until I think 166 degrees
Wemoy1
PA
I will be honest I haven't messed with it I took the door off it back in October the one day I had it out and I have parked it since.
