Swamps BFH Turbo
Lechlis
Virginia
I have a Swamps BFH turbo for sale. I had it on the truck from October until December when I sold the truck. Has roughly 2,500 miles on it. Looking to get $1,250 OBO. The shipping situation can be discussed if you are serious. I will upload pictures at my earliest convenience. I can be contacted at (276) 733-7269. Please text if possible. Thanks guys!
Link to the turbo: http://swampsdiesel.com/prestashop/en/turbo/136-bfh-turbo.html
Lechlis
Virginia
238cc/100% Injectors. I ended up with them instead of the 250s, sorry about the mix up. It did ok with the 238s, but 300cc+ would be ideal I believe.
Magnum PD
VA
Thought I would ask what the owner what he thought about it. As in didn't lite till late and does not tow
truckpullin_75
Olney, IL
I'm running one on the street with 450/400s and built engine and have towed lightly with it. Not exactly an ideal setup but it is doable.
Lechlis
Virginia
I only drove it on the street. It liked its RPMs but you could drive it around decent. You will have to relearn how to drive the truck. I honestly didn't think it was that bad, you just have to anticipate your next move. Don't expect to jump out and pass someone without a little premeditation.
PSDEng
Bellefonte, PA
I drove one on the street with 300/200s for a bit. It wouldn't come on until 2100-2200. not ideal but doable as stated before.
truckpullin_75
Olney, IL
Here's a video I took a while back with mine. It's a cell phone video so not very good quality but might give a little bit of an idea, keeping in mind mine is lowered compression, ported heads, and custom cam grind, as well as needing to get it live tuned for the current setup. Can't see the boost gauge but you can hear it come on.
http://youtu.be/Q5jPgMVF***
Lechlis
Virginia
I don't think I got quite the "wow" factor as someone with a larger set of injectors would. I never seen more than 45 psi with with. I was making a consistent 52-54 on the 66mm H2e.
Lechlis
Virginia
Here are some pictures. Once again, 2,500 miles. Play is well within spec. Comes with an extra compressor housing V-Band clamp. $1,200 OBO shipped to your door.
