Terminator duals
gobstopper909
Quinton NJ
Price drop!
This listing is for a 7.3 power stroke. I had plans of 300/200's, but $$$ never came my way. It originally started off with a stock superduty 17 degree pump I had modified by joey @ terminator engineering. I found a used front pump and adapter on powerstroke nation that needed to be put together.
I bought it and realized I could not put it together myself. I sent both pumps to joey and he mated them together, updated both pumps and installed a remote ipr on it with the latest custom machined mating adapter.
This listing includes the ready to run hpop's, remote ipr, ipr dump line, tapped hpop reservoir (for ipr dump) and obs hpop fittings. Bolt it up with a new gasket, and run any size injector you want. These pumps put out 3100psi at wot with 250/100 hybrid injectors and also helped me put down 541-1060 rwhp on a dyno.
I'm downsizing my setup, therefore I dont need a dual hpos. The only trades I would accept are a brand new aftermarket pump that would support small hybrid injectors. Thank you
