brian89
Is there anyway to bench test a trans to see if it will shift and run properly? visual inspection? Electrical test?
And you do that with a trans dyno. A really good trans shop might have one, and for a little $$ might test one for you.No. You will need to get a load on it to determine any of that.
There's one possibility if they are near you.Thats not true. NADP has a trans dyno
