Testing the HPOP
ac3496
I do not have access to AE. My truck does not start and I want to know if I am testing the HPOP correctly. I disconnected both oil lines from the pump at the heads, I plugged one line and on the other I set up a liquid filled gauge with a 2000 psi max rating. I cranked it and I am only getting 175 psi. The HPOP reservoir is aways full too. Before I did all of this I replaced the ipr with a new one from ford and a new HPOP gasket as well and the truck still did not start.
I have a 1500 mile srp1 that is starting to take two 8 second cranking cycles to start when hot now. Lol....
