Thinking about lowering my truck
Bremen, Ohio
Anyone had experience lowering an F250 2 wheel drive OBS? What all is involved? I will be putting a set of 30" tall slicks on the back from DZL JIM. Has anyone used the DJM dream beams on an OBS? I remember a while ago it said that you could not use them on a diesel application. I have not seen that written anymore in my recent search. Just wanting to make sure before we order anything.
What are your thoughts guys?
SouthFlstrokin'
It should be fine... Contact djm and ask them. I believe a guy on here lowered his 2wd dually.
Moremph
Foster, KY
Lol we took all but one leaf and the overload out of the back of joey's we havent done anything to the front we thought about clipping the coil spring or f150 front coils
Travis
tjl
Ohio
I just put a DJM 3/4 lowering kit on my dually. It's a good kit. I think you'll like it. My truck uses the same kit as your truck would need. I ordered mine off of Ebay. It included front I-beams and shocks, rear spring hanger, shackles, and shocks. Be sure to order the 6* pinion shim to correct your pinion angle. The only issue I ran into was I can no longer use the front sway bar. If I want to use it I'll have to modify it. So far I haven't had any handling issues without it. The lower center of gravity helps a lot.
Bremen, Ohio
Thanks!
I ditched the sway bar a long time ago... It had to be removed so that the intercooler would fit... LOL
What are the chances of taking a look at your kit sometime?
tjl
Ohio
Sure, I'm going to be at the OCR spring dyno day in Dayton next weekend and I'll be at TS. I just looked it up. You're only about an hour away from me. I was actually able to keep my sway bar with my intercooler. I used a 2" block to lower the mounting point and it workd perfect.
DZL JIM
North East Ohio
Nate,
Have you looked into cutting the coils?
I was going to do that to my drag truck but quit racing before I did.
Looked easy enough, maybe heat and bend the last coil to fit back in the bucket.
tjl
Ohio
The only draw back to that Jim is it throws your front end geometry out of specs. It makes it hard to get your camber back in spec.
TANK'S 250
Belle Chasse, LA
If your going to lift a truck....why not just buy a Jeep?
Jeep can't tow 17,000lbs
....or take the wife, 2 kids, 2 dogs, and enough luggage for two weeks across the country...
....and lastly....Jeeps don't get VIP invitations to Ford sponsored Monster Jams...LOL
