bigwheel
Right now on my truck I am running 37" Toyo MT. I like the way that they are waring but maybe looking to go down a tire size. We have a pop-up truck camper that sits on the truck most of the summer that weight's 1700lbs. loaded. So not a lot of weight. The 37/13.5/17 Toyo's are a E load range that can carry 4300lbs at 65 psi I belive. If I go with 315/70/17 Duratrac's they are 3195lbs at 50psi load range D.
So if I go next size down will the tires handle the load?
Is there another tire size or tire that would be better?
Thanks
Thanks
