Too much DCA?
mjonesjr
Salem, IN
I am going to be putting a coolant filter on my '97. WIX makes a filter that has 12 units of DCA built into the filter.
Is it possible to have too much DCA into the coolant?
Tom S
If you already have DCA in there use a no DCA filter on there or fresh coolant with no DCA
mjonesjr
Salem, IN
I put a bottle of WIX DCA in when i flushed the radiator a couple months ago. I need to pick up a couple of the test strips and check it.
mjonesjr
Salem, IN
I think it was a 16oz bottle.
I am going to pick up some of the test strips. I wonder if the local parts store has them.
mjonesjr
Salem, IN
I will be by an International dealer tomorrow so I will pick them up.
Are they just stick them in the reservoir tank and it will turn a certain color?
Tom S
Yes you dip them and then compare it to a color chart. Fleetgaurd is the ones I have used in the past. Hopefully they will have the 3 packs of them.
old man dave
Petaluma, CA
It takes 3-1/2 to 4 pint bottles of the FW-16 or Fleetgard DCA for the right concentration of DCA for the 32 quart cooling system.
