mustube
Took the turbo out to put a rebuild kit in, some bellowed up pipes and delete the EBPV and found out my turbine wheel is all chewed up. Does this happen from a worn out turbo or did something that was once inside my engine decide to come out? There was side to side shaft play but no contact with the housing on the compressor side, zero in and out play. Is this something I should look into more or should I put it back together with a new turbine wheel/shaft and call it good?
Edit: I should note that the truck runs fine except for having symptoms of worn out injectors.
