Spindrift
For loads greater than 15K, is there a turbo better than the PowerMax, assuming you will stay with a single? I was looking at the BD Thruster 2 and the salesperson said that the PM flowed a lot more air, at half the cost.
there are better nonVGT options than the thruster for much less money.
The thruster is a 62mm non vgt, it will own the powermax for airflow. Honestly, there are better nonVGT options than the thruster for much less money.
A little baby 62 will out flow a pm that much?!
Not if the Pmax has the newest 11 blade single plane wheel that is available for it. If you're looking for a towing turbo that is brand new, I think it is hard to beat a Powermax with that billet wheel for the money.
I never had luck with the batmo wheel, I now have the single plane billet wheel on my powermax. Egts get a little warm still, but I can hold 1200 rpms pulling my 16-18k 5th wheel. I can't say I seen a egt change, but the low end power was worth it.
