TPS
eng53ine
Ohio
Do I have to buy the whole pedal to replace the tps?
2002 with adjustable pedals
eng53ine
Ohio
I think I saw a Dorman replaceable module, but I would not use anything from Dorman.
Ok all I can find is stuff for non adjustable pedals or $599+ pedal assembly gonna try some contact cleaner hopefully that help.
Did get a code I believe it was po122
02 ccsb, lariat, 7.3 auto, 4x4, 4" duals, 6637, IH bellowed up pipes, RiffRaff billet wheel.
eng53ine
Ohio
Would a junk yard pedal be worth a shot for the right price
eng53ine
Ohio
Absolutely.
Think I'm gonna have to try this route
Get rid of the yuppie pedals...
Would love to but they make for a lot less readjusting after the wife drives it
That pretty well sums it up.
Thanks for the replies guys
eng53ine
Ohio
well got a pedal from the junkyard plug it in and the truck won't start, the wts , cel , check gauges, the battery lights all stay on. Talked to a parts guy at sunrise and he said it should work as long as the part# is the same which is
9F836. then he said only the pedal from an 02 or 03 will work, so heres my question.
Is there any year specific parts to a part#?
my pedal: 2034 9F836-DD
D074.02 C54
junkyard: 3C34-9F836-BF
D182.04 B48
the part# for a 2004 6.0 adjustable accelerator pedal is also 9F836
gnxtc2
Bergen County, NJ USA
eng53ine
Ohio
The 9F836 is the base part number. The first 4 numbers are year/model series (F series, E series, etc, etc). The last letter (s) are the revisions.
The numbers you posted are engineering numbers.
http://www.fordification.com/tech/partnumbers_overview.htm
The dealer should be able to cross the engineering numbers to part numbers.
Billy T.
[email protected]
thanks
According to this my pedal is for a 02 the junk yard pedal is for and 03
both for a medium duty truck from vehicle center 4. I guess its just a junk pedal.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2235013
eng53ine
Ohio
Junk yard pedal is for a 03-04 6.0
