traction bars (cal tracs)
Nic
Santa Fe, Texas
well unlike the title, i know cal tracs arent bar style setups...any one have these on your 6.0? how do you like them? any other opinions on other trac bars? post pics??
JDub
Hooper, Utah
I love the Caltracs on my Dmax... install kind of sucks because you have to take the springs out, press out the front bushings and install the new aluminum bushings. But the traction bars work great...
stonepusher
San Antonio
I have them on my truck and they work awesome! Haven't had a chance to run it at the track yet but it def puts the power to the ground.
Nic
Santa Fe, Texas
^^ seems like theyre worth the money. Ive heard of some saying you cant tow or daily drive with them. i dont believe that but they look like theyre a great product. Just what im looking for. To put the power to the ground
2wd-fire
ive read a bunch of reviews and the only thing bad thing i heard is sometimes they will kinda bang loud i plan on getting them. any one of you guys have them can you tell me your best 60ft times on 2wd of corase thank you
AllanB
Mississippi
There are 8 and 9 second cars running Caltracs, so 60' times will vary according to setup, power level, weight, type of slicks, reaction time, etc
2wd-fire
oh i was talking about street driven diesel trucks
AllanB
Mississippi
I will let you know in a couple of weeks. Just got mine in but crashed the front of my truck just a little so it is going in the body shop in the morning. I am not taking about the truck in the avitor, I have a 08 2wd also.
stonepusher
San Antonio
I can say from a dead stop it hooked up 80% better than it did before, the great thing about cal tracs is you can adjust and unload them whenever needed.
2wd-fire
i wonder what the bang comes from
i should of explained it better. it what happes when you have the pre load to tight for just driving around and not racing and you hit pot holes and such i was told tho you could put piece of rubber hose around the bolt that contacts the leef spring and it will be alot less nosie
Pizza pig
MD
caltracs are noisy, just due to the nature of the design. Its not at all bad daily driving, just dont put too much tension on them.
AllanB
Mississippi
If your driving at preload and someone wants to race. Is there a way to mark them so you can go back to loaded? Just wondering how far to load them and how you keep up with it if they are unloaded most of the time.
JDub
Hooper, Utah
so when you race you tighten them up?
They work great the way I have them set for the street. If I were going to the track I'd remove the hose and set them up with slightly more preload. They don't need much.
