Tranny and fuel line diagrams?
Littlenoz
I have a 97 f250 Powerstroke that I just bought. Don't know much about diesel but I'm learning. I have a fuel and transmission line leak looks to be in the front end of the truck by the front axle. Just wondering if anybody had a diagram of the fuel and transmission lines to help me out. Thanks
Littlenoz
I'm not to sure about the fuel leek. I came home from work and there was a puddle of diesel under the truck.
Magnum PD
VA
Fuel pump may be bad. Can you look under the hood and in the valley to see if you can spot any leaks?
m j
BC Canada Eh!
these trucks leak from every oring when they get old
dieselorings.com is your friend for that.
on mine the final leak was the vibralok fuel fittings at the rear of the head
I am ripping it out for efuel
Pstroke96
Connecticut
thoes fittings have a rubber sleeve that goes over and thats what holds the line down, if thats the issue you can get them from the international dealer, they are called fuel line sleeves, just dig out the old rubber push the new one on and you are good to go
Littlenoz
Well I ended up bringing it to a mechanic because I just didn't have the time to fix it myself plus it was leaking power steering fluid too. Now there's no leaks anywhere! Thanks everyone for your replys
