Tranny and T-case Question
purpleheart350
Rokwall, Tx
So I found a 95 350 4x4 5 speed, wrecked i believe (just missing the bed) for $800. Will the t-case swap on to an E4OD. I would like to pick it up and swap everything in to my truck (4x4 wise) if it aint broken or too bad. And for those who have done it how long does it take to swap out once you had everything ready to go in? Thanks for the input.
Mark Kovalsky
SE Florida, USA
It won't bolt to your E4OD the way the trans is now. You have to rebuild the trans with a 4x4 output shaft and extension housing. This involves taking EVERYTHING out of the trans, installing the new output shaft, and rebuild the trans.
