Trans cooler line disconnect tool
SaNnDnSurF
SATX
Anywhere I can find one locally my radiator needs to be fixed and truck is down till I get it fixed. San Antonio tx
ford rules
You can just unthread the fittings out of the radiator as long as they arent rusted to the lines.
SaNnDnSurF
SATX
Ya but how do u get them back on I've always heard that was a no go, I need to have the holding tank replaced on the radiator.
bretferd
Cape Coral, fl
Don't do that. I found out the hard way that it will leak coolant. There is a gasket supposedly(never found it) between the cooler and inside of the radiator. I just used blue silicone and its working for right now.
I don't know the actual size that you need but I know autozone sells a kit with a few different sizes.
HOOV3R
Central PA
If its the newer push connect style, you will need a Ford 1/2 trans line disconnect tool.
ford rules
I did it on my truck and no issues for 15,000 miles so far. You just need to make sure the o-ring is still seated on the cooler when you tighten it back up.
ToMang07
Mainah!
Does it work like the fuel disconnect?
If it does, I got mine off with a couple small flat tip screwdrivers.
ghohouston
Lewisville,Texas
ive always been able to use a regular fuel line quick disconnect on them with a little elbow grease. never messed one up. idk why some people say they wont work.
