Trans Flush
riemer
Grove City, PA
Do you guys take your trucks to the dealership to have the transmission flushed and filled? Or do you do it yourself?
i dont flush as it upsets any settled material in the cooler that once flushed can clog solenoids etc and cause trans damage.
01PSD
Smithfield, NC
The only proper way to flush a 5R110 is by utilizing a heated flow machine.... which some dealerships have. Mark will probably chime in here and provide further input.
Mark Kovalsky
SE Florida, USA
That's a bunch of bull.
That's correct.
Csilva187
Pull pan, change solenoid, change filter (depending on job# for location), reinstall clean pan, refill with mercon lv or whatever. It's easy, I can even do it.
StrokiNDieseL
Geneva, Fl.
Got a whole case of Lv last week & all the filter for a job 1. Only got 48k but I'm not original owner, I've done all my other mods. Thanks
